Bike and Cycling Forum > Bike Rack > Beginners Forum > Flat tires
Old 07-20-2010, 12:15 AM   #1
Flat tires
OK, it's me again with another dumb question.
I am continually having flat tires, especially the rear. I have installed a new Continental stiff walled tire (700 c) and am inflating to 110 pounds (or about). I seem to be getting small pin sized holes in the sidewall section of the tubes. I am using good patch kits and, at times have good luck, but at other times have no luck at all. I am careful about my riding and try to stay off of areas of the road that are too bumpy. By the way, I am a bit over 250 pounds which I am sure, doesn't help.
Today I rode for 20 miles without a problem, put the bike on the car bike rack, and 1 hour later the tire was flat. Can too much outside temp have any effect? It was about 105 today.
Thanks,
CVGreg
cvgreg is offline   Reply With Quote
Old 07-20-2010, 12:28 AM   #2
whyeyebike's Avatar
There is a good chance your issue is the installation of the new tube. You may be getting the tube pinched between the tire and the wheel. If this is the issue, within a few miles you would get a puncture.
whyeyebike is offline   Reply With Quote
Old 07-20-2010, 12:29 AM   #3
whyeyebike's Avatar
And for the record, that is not a dumb question.
Old 07-20-2010, 02:08 AM   #4
Not at all. It's a rather common one.
Industry_Hack is offline   Reply With Quote
Old 07-20-2010, 05:14 AM   #5
Are you getting two little punctures that look like a snake bite? Those are pinch flats caused by getting a little piece of tube caught between the rim and the tire bead.
I recommend that you go to this site and read up on the subject. Flat Tires
It's not a dumb question. Flats can be very frustrating.
eaton is offline   Reply With Quote
Old 07-21-2010, 12:38 AM   #6
Well an old school teacher told me the only dumb question was one you already knew the answer to, and sometimes even they weren't if the person next to you didn't know and you knew they were to scared to ask it themselves.
A couple of other things to check. First check the inside of the tire, both by looking and feeling for anything sharp. Any thing that makes if feel like a prick can have you singing Pop Goes the Tire Now (sung to the tune of Pop Goes the Weasel") when put under pressure. Also check the rims and rim tape. Spokes can sometimes cause problems.
Just curious about others experiences, but a few things almost always cause a flat.
1. I am almost always going to have a flat when I forget the repair kit
2. I never have a flat close to home or the car. It's always half way out on the longest section of the ride with the maximum walk home.
3 I always seem to have flats at night when I can't see to change them.
4. I always have a flat when I am right next to an air source, but I have no adapter for the presta valve stems to the schrader valve stems and end up using the pump anyway
photosbymark is offline   Reply With Quote
Old 07-21-2010, 02:17 AM   #7
My neighbor brought me a 20" bike with a flat. I removed the tire, noted the electrical tape on the crappy wheel, and gave it two layers of proper cloth rim tape. After patching the tube, I reinstalled and inflated. BOOM! Tube came apart because I patched it on the seam.
Bought the kid a new tube, installed it about ten minutes ago. Was fiddling with the brake, when BOOM!, this tube blew up as well, same spot. I've narrowed it down to the rim being somewhat egg-shaped. They are going to heed my suggestion to either find a free back wheel, or add this sweet chrome Huffy to the parts bin.
Old 07-21-2010, 03:20 AM   #8
Xela's Avatar
Truthfully, 110 psi sounds a little low for your weight. Try going up to the max pressure the tire will handle. The ride will be a lot rougher, but it should help with the flats.
Xela is offline   Reply With Quote
Old 08-04-2010, 10:16 PM   #9
Thanks for all the replys. One bike tech finally found the answer.
The rim tape that was on my rear rim was very narrow. In a few spots the tape did not cover the spoke reset totally and when my weight would bounce on the tire - flat! Since I have new rim tape on the rim, I have not had another bit of problem/
Old 08-05-2010, 12:01 AM   #10
Ridin Dirty
Hardtail's Avatar
Yeah rim tape and some Panaracer XC Pro 26x2.1s and no issues!
2010 Trek 3900 Disc in Matte Orange
So how many differant countries have you gone riding in/on?????? USA, Canada, Hawaii(oversea..lol), Qatar, Iraq and South Korea now.....more to follow though!
Hardtail is offline   Reply With Quote
Flat! Doohickie Commuting / Touring 9 04-21-2011 11:37 AM
Flat Tires s2pyd Commuting / Touring 29 09-26-2010 07:25 AM
Flat Tire Solution Gallagher9 Mountain Biking 18 10-28-2009 03:29 PM
It is goathead season, can we say flat tires... jeepster93 Tires / Wheels 22 09-15-2009 03:23 PM
  • rss
  • facebook
  • twitter
