Bike and Cycling Forum > Bike Rack > Beginners Forum > gear shifting - avoiding cross chaining for newbie.
Old 01-02-2012, 10:57 PM   #1
So - I got 2 rings at the front, 1 big, one small. and then 9 different positions available at the back.
I know that i'm not supposed to use big and big, and small/small.. but what combinations can I get away with that dont stress the gears/cross chain?
I've seen guides like the image below which depict 3 chain rings at the front, but nothing for a bike with 2 chain rings?
Can i get away with using the big chain ring all the way up to the second from largest cog etc - or not go past the 3rd largest etc? hope the question makes sense.
goldTopDeluxe is offline
Old 01-04-2012, 12:25 AM   #2
BeginnerCycling's Avatar
Many people say with 2 chainrings on the crank, cross-chaining is not so much of an issue. Probably still best to avoid the extremes if possible, but I believe the added distance by having a third ring leads to more concern over cross-chaining on triple cranks.
I ride at night -- here are my tips for Night Cycling
My Blog: Cycling For Beginners
BeginnerCycling is offline
Old 01-04-2012, 01:02 AM   #3
You're right that the only thing to worry about is being on the big chainring big cog and small chainring small cog. Most of the time you're going to get an audible reminder because you'll get some chain rub with these combos. Other then that anything goes.
Noel is offline
Old 01-04-2012, 07:34 PM   #4
DX's Biggest Member
CTD50's Avatar
I'd call your diagram 'right on'. Some people don't care, but there are 'proper' ways to do things, and what you diagrammed is right for multi-gear systems.
SEZ THE KONA: "AH'M DEAD SEXAY!"
CTD50 is offline
Old 01-05-2012, 12:36 PM   #5
wild's Avatar
On my 3x9 and 3x10 It will rub if you are in the middle chain ring and the inner or outer most gears. evean trimed out. So I shift chain rings if I nead that lower or higher gear, Allso I think there is a little drag on the chain that you can feel if you are cross chaining, shift chain rings and it feels a little easyer
wild is online now
Old 01-05-2012, 09:19 PM   #6
From what I understand, one issue with being on the most extreme front and rear combos. is that it not only causes chain rub but, the real problem is that it will wear out the springs on the rear mech. faster.
Noel is offline
Electronic shifting? bikebum1975 General Bike Discussion 16 09-21-2011 04:37 AM
cross bar ? lonewolf Beginners Forum 6 03-09-2011 02:28 AM
Billy Cross rola643 General Bike Discussion 4 02-28-2011 10:31 PM
Avoiding a heat stroke!! Angelica Training / Health 4 07-30-2009 02:49 PM
Shifting Gears backroader Road Bikes 3 07-06-2009 05:35 PM
