Bike and Cycling Forum > Bike Rack > Beginners Forum > Mountain Bike on the Road
Old 09-14-2009, 01:41 PM   #1
I have a Specialized Epic full susp. MTB. I have recently been using it to commute to work (3 miles one way). It has 26x2.0 on the front and 26x2.10 on the rear. The more I ride on the road the more I wonder if I can put more of a hybrid or road bike tire on the bike. Would it make a difference in road performance?
nhcop is offline
Old 09-14-2009, 01:51 PM   #2
Liked 2 Times on 2 Posts
If you are riding with nobbie tires on the road, going to a commuter type slick or semi slick will greatly improve your performance. Your bike will be faster and handle better.
When I used to commute on my mtn bike, I used Continental Town & Countries.
Old 09-14-2009, 03:55 PM   #3
bantam700's Avatar
hybrids and road bike tires are a different size than mountain bike tires, but they do make some tires for 26' mountain bike wheels that are more suited to riding on pavement
bantam700 is offline
Old 09-14-2009, 04:39 PM   #4
I just went to the local bike shop and picked out a nice tire that had nobbs on the sides for traction in the deep and semi-smooth onroad tred near the center. They work pretty darn well in all sorts of environments.
elementfiftyfour is offline
Old 09-14-2009, 04:51 PM   #5
Administrator
TxCyclist's Avatar
What would you consider then a mountain bike tire with road type tread. Not a hybrid tire?
Unanswered Threads
TxCyclist is offline
Old 09-20-2009, 12:20 AM   #6
So im thinking I might pick up a cheap road bike for next season so I can have the best of both worlds. I really enjoy riding offroad, but I find it convenient to bike to work were I only live 3 miles away.
nhcop is offline
Old 09-20-2009, 12:45 AM   #7
Nothin' wrong with havin' two bikes.....or three...or four...................................
Old 09-20-2009, 02:14 AM   #8
mtndoc's Avatar
I'm startin to see the wisdom in this....
mtndoc is offline
Old 09-20-2009, 10:55 AM   #9
Cycling for life
I can see the logic as well. But, only want one bike to own. Still planning on a Crosstrail or something very similar at xmass. I think after that another set of wheels & tires may be in plan, will have to ride and see.
Skidmark is offline
Old 09-22-2009, 01:15 PM   #10
Brit
RoyEveritt's Avatar
When you buy road-type tires, take note of the maximum pressure on the sidewall. Some have a max of 50psi, compared to, say 75psi for others. If you can run your off-road tires at a higher pressure, the difference in performance won't be so great.
That said, good road tires have a lower rolling resistance and they'll usually be narrower, of course, which also helps. I used 50psi road tires (26X1.9 I think) for our recent long ride and they were fine, but I'd ridden it on some fatter knobbly tires at higher pressure and it felt fast then, too.
It was a borrowed bike, so I'm afraid I can't remember what tires they were!
Roy
RoyEveritt is offline
Road bike or comfort bike Mike1jw Beginners Forum 24 12-03-2009 02:46 PM
Mountain bike to touring bike transformation bohunker General Bike Discussion 8 09-24-2009 08:37 AM
Road vs Mountain Pedals ratfink Beginners Forum 21 08-15-2009 04:02 AM
Best Road Bike? Chain Road Bikes 15 07-20-2009 08:19 PM
