Bike and Cycling Forum > Bike Rack > Beginners Forum > Proper Braking Method on a Road Bike
Old 10-01-2011, 03:32 PM   #1
GiddyUp
Weav's Avatar
Hey guys, I just read an article in Bicycling magazine where someone stated that the proper way to brake on a road bike is to use 60% front brake. And if you're descending then use more power as needed on the fronts. I have always used my rear brake for most of my braking as it seemed to me like the safer way to slow my bike down with no risk of sliding forward or worst case going over the bars if you slam on the fronts. Proof of this is that I wear my rear pads down twice as fast as my fronts.
Any opinions?
Weav is offline
Old 10-01-2011, 04:05 PM   #2
Rat Biker
bikebum1975's Avatar
Yep front braking has the most power. Just takes a little getting used to it getting over the fear of flipping over the handlebars if you are new to them. I usually use my back break to feather off speed comb the 2 brakes when going really fast. Play with them find out what works for you just don't lock up the front brake
You might be a cyclist if....
Your bike is worth more than your car.
You put more miles on your bike than your car.
Weather forecasts can be broken down into 2 categories: good biking weather, bad biking weather.
Honey, it's just a bicycle. and i REALLY need it to excercise, and to ride it to work.(hehe)
Someday when I grow up I will probably lose interest in toys with wheels, but until then..
bikebum1975 is offline
Old 10-01-2011, 04:07 PM   #3
Dubgurl's Avatar
This is true. If you notice your car will wear the front breaks down much faster than the rears, and your front brakes are much bigger than your rear brakes. There's other reasons than this but the reason I know of is because if you lock up your rear brakes and not your fronts, the back part of your vehicle (car, bike, train, whatever) will not be decelerating as quick as the front. The reason is now the back is going to try to pass the front and making the vehicle more unstable. The opposite is true if the front locks and not the back, the front of the car is going to try to pull away from the back, you obviously have no steering, but you won't suddenly be facing the wrong way, which is bad in a corner but it's quickly and easily corrected by releasing both brakes then starting the same method of braking again.
Obviously this is nearly obsolete on cars because of anti lock brakes, but I haven't seen a bike with ABS yet (bonus points to anyone who can find one lol)
Someday, I'll have enough money for a big girl bike!
Dubgurl is offline
Old 10-01-2011, 06:56 PM   #4
Liked 4 Times on 4 Posts
Likes Given: 5
Sheldon Brown's advice on braking is well worth reading. Click on underlined text for link.
Quote from the link "The fastest that you can stop any bike of normal wheelbase is to apply the front brake so hard that the rear wheel is just about to lift off the ground. In this situation, the rear wheel cannot contribute to stopping power, since it has no traction."
qmsdc15 is online now
Old 10-01-2011, 07:04 PM   #5
Eocyclist
LarryM's Avatar
To stop real quick, shift your weight back and apply both brakes ... with more pressure on the front brake than the real. If the rear wheel starts to lift or skid, ease up on the front brake until it settles down. A skidding or lifting rear wheel acts as an anti-skid indicator.
Here is a good video on how to stop quickly from IPMBA
Here is a good description of the quick stop from the League of American Bicyclists web site League of American Bicyclists * Tips and Techniques
Photo of an officer executing a quick stop.
LarryM is offline
Old 10-03-2011, 01:12 PM   #6
Xela's Avatar
Liked 5 Times on 4 Posts
Likes Given: 6
Cars are usually set up with front brake bias. This is because during braking, there is a load transfer to the front tires meaning the front brakes are the bigger component of your stopping power. Also, as the load is transferred off the rear, they are more likely to lock, so you actually want less braking back there. The tractive force of the tires is a function of the normal force (or weight that is pushing it down) on each tire. The more normal force, the more tractive force available to an extent.
Tires have what is known in classic vehicle dynamics as a friction circle, thought data shows it's never truly a circle, which they have to operate in as shown below in the generic example which I took from driftingstreet.com:
What the circle demonstrates is that if you ask a tire to do either pure acceleration or pure braking by either spinning the tire or locking the tire, there is no traction left for cornering. This is what Dubgurl was referring to. Lock the rear first, it's easy to spin-out. Lock the front, you lose steering.
However, as Larry pointed out, we can influence the weight transfer on our bikes by shifting our body weight. Without shifting our weight, the rear brake could easily lock as the load is transferred to the front due to the reduction in normal force. By shifting weight, we can more heavily brake the rear without locking it while also applying heavy front brakes.
Xela is offline
Old 10-03-2011, 04:01 PM   #7
Locking either is bad news. As far as that pic above goes it would really a bummer if you lock your elbows and knees too for that matter. Get in that position and apply the brakes and the bike slows down. Mr Newton says an object in motion will remain in motion unless acted on by an outside force. Your body is moving, but the braking force is applied to the bike. Unless you have parts of your body that are secure which in a sense makes you a a part of the bike, the body will keep moving. Guys look where you would hit.
Now just from a common sense red neck perspective, if you really NEED to stop that fast one of two things has likely happened. 1. Someone else made a mistake. In that case the surprise factor, the realization of just how fast you need to stop, the reaction time needed to not only hit the brakes but move the body into such a position to save a few feet. The time needed to go through all those processes is likely take most of advantage away from a slightly shorter stopping distance.
2. You made a mistake. You became complacent. You lost concentration for a moment and didn't keep fully aware of what is going on around you. From riding too fast in a very congested area to not watch to see if the other cars are respecting your position on the road, awareness keeps one from needing to stop that in the first place. Yet it also makes it more likely that you could pull the technique off because you are not surprised by the need.
Motorcycles going at higher speeds often make the choice to lay the bike down rather hit something solid with a bike. Road rash is far better than a solid impact to the head. IF you attempt the above technique and it fails, you still can't stop and you then still hit something, it isn't going to be pretty. Going down isn't always the worst thing that could happen.
photosbymark is offline
Old 10-27-2011, 06:43 PM   #8
Eocyclist
LarryM's Avatar
I just noticed that the photo of the LEO quick-stopping is displayed on theTwoSpoke Home page today (10/27/2011). A few more comments on the technique seem appropriate.
The best video I've seen about the quick stop is the one from IPBMA that is embedded in my previous post. The best text description I've seen is in John Allen's excellent booklet, Bicycling Street Smarts, which is available on line as well as in print. His quick stop discussion is at Bicycling Street Smarts, Chapter 6: Using your Brakes
Like any emergency maneuver, it should be practiced until it becomes ingrained in muscle memory so it can be executed without having to think about it. Shifting weight back and down while modulating the front brake to avoid skidding or lifting the rear wheel pays off in a substantial decrease in stopping distance. In a real emergency, just inches can make the difference between a good story to tell and a serious injury.
Larry
LarryM is offline
Old 10-27-2011, 08:48 PM   #9
BeginnerCycling's Avatar
Great site for advice -- I just wanted to point out that folks should read down through the "When to Use the Rear Brake" section too -- the rear brake comes in handy when traction is bad (wet, gravel) and when turning.
I ride at night -- here are my tips for Night Cycling
My Blog: Cycling For Beginners
BeginnerCycling is offline
Old 10-27-2011, 08:58 PM   #10
Administrator
TxCyclist's Avatar
Sheldon Brown was the standard. I still visit his site from time to time.
Unanswered Threads
TxCyclist is offline
Proper frame size -- ?? G6612 Road Bikes 7 09-19-2009 04:08 PM
Smoothing rim braking surface Xela Tires / Wheels 3 08-18-2009 05:58 AM
Proper nutrition Grape Ape Training / Health 4 08-09-2009 06:49 AM
