Bike and Cycling Forum > General Forums > Lights / Electronics > mm Tire circumference for trip computer
Old 05-21-2011, 09:55 PM   #1
I have 700x35C tires. The manual seems to say to set the circumference at 2205. It was not written with English as the primary language, and leaves much to be desired.
I went on a ride with someone else, and her computer said we went 5.68 miles while mine says 8.85. My phone GPS more closely confirms her number (5.4 mi).
I went poking around the Internet to find the real circumference, and found two numbers: 1370 and 2168. Just doing a ratio between what my GPS stated and the the numbers on my odometer, I think the 1370 number is more accurate.
I am not looking for 100% accuracy, just something closer than 3 miles off. What number has anyone else used in this setup?
dakuda is offline
Old 05-21-2011, 10:24 PM   #2
Vendor
PlatyPius's Avatar
The only way to do it right is to do a tire roll-out. Otherwise, you might as well leave the computer at home.
PlatyPius is offline
Old 05-22-2011, 03:27 AM   #3
Xela's Avatar
Liked 5 Times on 4 Posts
Likes Given: 6
I was going to post the same thing. Dakuda, are you familar with how to do this?
Xela is online now
Old 06-30-2011, 11:40 PM   #4
For what its worth my 700x35 role out to 2172. Readings have always been pretty accurate.
Simon
storksb is offline
Old 07-01-2011, 02:45 PM   #5
kneedrachen's Avatar
Liked 4 Times on 4 Posts
Likes Given: 9
I'm not but am curious as to how. I have an idea, but would like to hear from the collective.
kneedrachen is offline
Old 07-01-2011, 03:19 PM   #6
A roll out test is measuring just how far the wheel travels in one rotation of the wheel. That is what the computer uses in its math to compute everything else.
I use a some masking tape. Some use grease pencils. Lots of things you can use. Put a mark or reference point on the ground, and one on the wheel so they line up. Then you push the bike forward till the wheel rotates one time with the mark on the wheel as close to the same position relative to the ground as you can eyeball. The put another mark on the ground. The goal is to get that distance one rotation makes. Measure between the 2 points on the ground. That's the distance you need.
Now it might be in inches and some bike computers want mm so you can either let one of the online converters make the conversion for you or you can multiply by 25.4. Thats the number most computers want
photosbymark is offline
Old 07-01-2011, 04:55 PM   #7
Likes Given: 9
Man, I am smarter than the average bear...that's exactly what I thought should be done. Okay, righteous self-promotion is over.
Old 07-01-2011, 08:40 PM   #8
And before long we are going to have to bail you out somewhere for stealing picnic baskets.:-)
Old 07-01-2011, 09:44 PM   #9
tomk's Avatar
There are typically two numbers - one for MPH and one for KPH. The 1370 number is the correct number for MPH. Here is a chart: http://www.sigmasport.com/us_media/startseite/abstracts/48/visuals/Baseline_Wheel_Size_Chart.pdf
The chart should get you pretty close.
tomk is offline
Computer jcans1409 Road Bikes 21 03-31-2011 01:57 PM
Bicycle computer/speedo problems...... greenhorn General Bike Discussion 11 03-18-2010 11:29 AM
Which bike computer to buy? QueSera Hybrid 10 01-21-2010 11:10 AM
GPS Computer? Skidmark General Bike Discussion 21 12-14-2009 04:51 PM
