Once again, I would like to note that my "Math of Speed" is specifically to address the issue of the danger that I have no control over. Vehicles passing me.
See the discussion here:
http://www.twospoke.com/forum/f30/bicycle-safety-math-speed-3675/
Any other factor can have the danger reduced, or eliminated, by the application of method or equipment.
Bike:
#1 Make sure bike is in good condition. Before any ride, check tires, wheels, spokes, cables, lights, and especially, brakes. (Keep spare brake pads on hand, if your brakes seem inadequate, adjust brakes, then clean wheels & pads with alcohol, need better? Change your pads, and compare.)
#2 Armor your bike! Greatly reduce road hazard danger. Kevlar tires & slime tubes give you the confidence to run over many items, (rather than rapid redirection, near heavy traffic.) It's surprising how how much junk you can run into, tailpipes, bolts, broken glass etc.
#3 Plan your ride! Very often you can greatly reduce danger by taking less trafficked streets and by timing for non-high traffic time slots!
Visibility:
Be seen!
#1 Just found a better headlight than that which I previously recommended. 260 Lumens, low, high & Strobe mode, it zooms from wide, (notice me), to spot, (see road better), with the bonus of red ring for notice by side observers. $13 ... shipped!
CREE Q5 Style New Version 260 lumen Ultra Bright USPS!! - eBay (item 170419963648 end time Apr-12-10 17:43:44 PDT)
#2 Tail, turn signal & brake light.
Good idea to let people know your intentions, and you can keep both hands on the bars. (Some people think it cute when a biker "waves" to them.) Less than $10 ... shipping included!
DealExtreme: $8.65 9-LED Turning Signal Lights with Electronic Horn for Bicycles (2*AA)
#3 It might seem overkill, ... I taped an air horn to my steering column, ... nice red "panic button"!
Personal Gear:
#1 Helmet. I resisted it for a long time. Finally, ... after I, "made it my idea", instead of listening to everyone telling me to wear one, I designed my own helmet, by adding rear 5 led flashy thing, rear view mirror, made from "inspection mirror" and additional headlight (260 lumen, capable of low, high, strobe!) Being capable of directing a strobe directly at menacing vehicles is a real attention getter!
#2 Leather (padded) riding gloves. Not only do they look stylish and make rides more comfortable, but they give you some better contact points, in case of a road rashing.
No! ... I do not rely on speed as my only safety measure!
Speed is merely one of the tools that help reduce the risk.
EZip Engineering 101
Bike:
Visibility:
Be seen!
Personal Gear:
