1 - 14 of 14 Posts
Hi all,
I've been shopping around for road tires, 27x1-1/4, and was wondering if anyone has strong opinions. I am just a weekend rider. I didn't want the cheap stuff and didn't want to spend a lot either.
Do I need to consider tpi, wire-bead rim, etc? What brand tire seems to be most reliable? Is Michelin a good one?
Thanks for all replies,
Steve
♥'s Bicycles
What do you consider to be a lot of money for a tire? As I'm sure you've seen- tires range from about $10 up to well over $150. I usually ride name brand tires in the $20-$30 range and they work fine for casual cycling.
Discussion Starter · #3 ·
Yes, I have been shopping around and am thinking in the ballpark you mention. Have a favorite brand?
Steve
Schwalbe Marathon 27" Tire
The schwalbe Marathon tires are really good for urban/touring/commuting. These tires are almost bullet proof. Perfect for any daily rider they can take punishments. They cost around $25.
Discussion Starter · #7 · (Edited)
Just get some cheap CST rubber. You're not likely to notice any difference if you're only a casual rider.
Hi IH, I don't really know much about Cheng Shin Rubber, whether the quality is good or not, but the price difference between them and Continental or Scwalbe tires is not good enough to warrant personal injury if they fail at the wrong time. You could call me 'anal' when it comes to quality auto tires. I check the date code, made in USA code, and even the speed rating. I've had some close calls after buying auto tires on special and then have the tread separate on the highway during rush hour. As it turned out, the tires were 'old' when I bought them. So I am sorry to say that I would prefer to chose a quality high-priced tire over saving a couple of dollars. But thanks for your input.
Steve
A bicycle tire is not the same as a car tire. Unless you can get your bicycle up to 80+ MPH. Cheng Shin is the largest manufacturer of tires and tubes. They also own Maxxis brand.
No bicycle tire is going to fail on you, certainly not catastrophically.
bike tires
LOL Nobody talks about how much money they saved when they are on the side of a road fixing a flat. You Should always buy the best tires you can afford for your car and your bike. Your tires are the single most important component brakes coming in a close second. I like Schwalbe they work for me but you can't go wrong with Michelin,Continental or Victtoria tires.
Unless you're comparing something like a Gatorskin, I've never seen any correlation between the price of the tire and its resistance to flatting. Thorns and glass aren't averse to one brand over another.
Well I will stick my .02 in. Last year I baught a set of Michelin City trecking tires with Protek + $28 the first day I ran them I had a flat :mad:, so much for the protec + :rolleyes: . Thay make a simlar tire Michelin Pilot that has Protec Max $47 Maybe I should have spent the extra $$ :rolleyes: I know I will go with the Pilots next set.
Discussion Starter · #13 ·
I agree Jagonz. After looking around closer I think Schwalbe Marathon's reputation for being "bullet proof" is what I will ultimately purchase. :) I think I read something about a Kevlar belt, maybe?
Thanks,
Steve
1 - 14 of 14 Posts
