Odyssee Evolver brake mounted to the bottom of the seatstay. Stock 1BY4 pads. RBJ1 Steel rim. Pads are making square contact to the rim. But the thing won't stop the bike at all. The chromed steel rims are like glass. Would a different pad bail us out? Or can these pads be altered?
The brakes could be adjusted all the way against the rim but the tension in the brake lines can be too slack to apply enough pressure... just a thought Turn the knobs on the levers to tighten the wire, put some sticky grip stuff on the brake pad like a car does
you need to adjust ur brakes and a good chrome rim will stop you good, dont spray ur rim with windex or a cleaning supply like stated makes ur brakes loud as hell, and wont stop you right, just wipe them with a cloth
No. Evolvers if put on correctly should stop perfectly with stock pads. They are the best breaks ever made they should have enough torque to grab that rim, but you are right that some rims do slide through the pads. So try this ride it a lot so rubber accumulates on the rim also take the pads off first and rub them across the sidewalk making them course. If that does not work find some that are more soft and gummy. Just get that rim coated with rubber.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Two Spoke Forums
A forum community dedicated to cycling and bike riders and enthusiasts. Come join the discussion about troubleshooting, maintenance, training, trails, racing, reviews, accessories, classifieds, and more!
