Well I took the chain off and put it in the clearflow tank soaked it then brushed it and soaked it again, let it dry, then I lubed it with Epic chain lube. I seen that the lube seperated so I shook it well befor useing. I found the lube was verry thin and thaught it was comming out a little to fast lots of waste. I put the chain away untill next time to lube, I have 2 chains that I use, I like to let it drip and set befor I use it. I am going to make the hole smaller in the bottle, I want to cut down on waste and have better controle puting it on. I should be useing this chain next week, and will do the one that is on the bike now.
