Schwinn Avenue Hybrid and one calpier arm on the rear of my "V" brake does not spring back after braking, hence I am dragging a pad. I released pich bolt tension and squeezed calipers together and reset tension and it looke good but, after one brake the right arm does not spring back from the rim. The tension screw is no help so I assume (always dangerous) that I need to rest the spring tension rod on the arm of the caliper that is not releasing. Am I thinking correctly?
