On my bike I loaned to someone, the brake cable has been cut where it goes from the frame to the gyro. Is there any tip for fixing this without taking everything apart? Could I clamp the broken wires together with something then tighten up the rest of the system?
its worth a try. if it doesn't work, then you know what not to do next time. sometimes its best to learn from your mistakes. good luck
I joined 2 gear cables with a electrical connector with the plastic cut off as well as 2 screws holding the lapped cables I put araldite in there too left it for 2 days to set:thumbsup:
good point engyo my fixes are for the financially challenged. I wouldnt tie knots in brake cables but I have tied knots in gear cables and the strands of wire dont share the load evenly and are bound to break constant changes in tension eventually. .
