1 - 1 of 1 Posts
· Premium Member
Company Website - http://www.montagueco.com/bikes/paratrooper-folding-bike.html
Manufacturer - Montague
Specifications
Color Cammy Green​
Frame 7005 Series Aluminum with FIT System. Mono Tube Front and Rear Triangle with disc mounts.​
Fork SR Suntour XCT 80mm Suspension, disc mount, adjustable preload​
Rims Alloy, 36 hole, Double Wall. Machine finish brake surface with Aqua No channel​
Tires 26 x 1.95" Kenda Knobby Front and Rear Specific​
Hubset Formula sealed alloy​
Spokes 14G stainless​
Saddle Cionlli Mountain Double Density​
Seatpost 27.2 Ultralight butted alloy, 300mm​
Handlebars Ultralight butted alloy, 30 degree rise, 5 degree bend​
Stem Alloy threadless​
Shifters SRAM X-5 Trigger front and rear​
Front Derailleur SRAM top pull​
Rear Derailleur SRAM X-5​
Crankset SR Suntour 42/32/22 170mm​
Speeds 24 Speeds 11-32T.​
Brakeset Front: Promax with dual pad adjustment. Rear: Alloy V-style Promax levers​
Pedals Bear trap​
Bottom Bracket sealed cartridge​
Frame Sizes 18", 20"​
Stand over heights 29", 30"​
Folded Size 36" x 28" x 12"​
Weight 29lbs.​
1 - 1 of 1 Posts
