Need with getting right 8-speed SRAM shifter
Discussion in 'Mountain Biking' started by Neuner, Mar 16, 2010.
  1. Neuner
    Neuner New Member
    15
    0
    0
    Apparently I'm getting all mixed up between the brands and models for my shifting.
    I have a SRAM X-9 1:1 actuation ratio rear derailleur, a SRAM Attack Impulse 8-speed shifter and a Shimano XT 8-speed cassette. I need to keep this as cheap as possible till I'm able to upgrade so, according to the LBS I need a different shifter. They stated that the rear derailleur and cassette are compatible but I selected the one SRAM shifter that is made to work with the older, lower-line Shimano derailleurs. Can someone suggest an 8-speed SRAM shifter that is compatible with the 1:1?
    Forgot to add, looking for trigger not grip-shift.
    Thanks,
    Neuner
  2. CTD50
    CTD50 DX's Biggest Member
    793
    0
    0
  3. Neuner
    Neuner New Member
    15
    0
    0
    I don't understand your post because that is what I have now and what is causing the problem. I already have an 8-speed that is Shimano compatible. I need a 8-speed shifter that is SRAM 1:1 compatible.
  4. CTD50
    793
    0
    0
    OK, my bad, I misread; SRAM X.5 comes in 8-speed.
  5. Retmuter
    Retmuter Member
    378
    1
    16
    I've been running Shimano for years. Is there an advantage to the SRAM 1:1 ratio? I'm asking because an 8 speed perversion is planned. Chain is at max stretch, cassette is worn out, a bazillion miles on the freehub, now's the time to upgrade from 7. My derailleur is an old LX that works fine, but I'm already spending money and also re-dishing the wheel (which is still in fine shape). If there's a noticeable upgrade in shifting, I'm willing to change it too.
  6. i12ride
    i12ride Spin Spin Spin Tavern Member
    3,792
    2,059
    113
    Switch to gripshift and I have you covered.............as in cheap 3x8 set never installed.
