1 - 11 of 11 Posts
hi i lowered the saddle in the front to help with numness but if i lower it to much i feel like i am go to slide off. should it be level or tilled down ?
♥'s Bicycles
Generally, it should be level. Have you tried sliding it forward or backward to see if that helps?
♥'s Bicycles
My method of fitting saddles is "keep adjusting until it feels right" but usually the adjustment is up/down [in very tiny increments] with the seat post or forward/back on the rails. If it is a new saddle it may take a few miles before your butt and the saddle to become friendly with one and other.
greenhorn
Might be the saddle. Even an expensive one needs to fit you. Before you go crazy on adjustment make sure it is a male friendly in the important places. Everyone's butt and bones are different, you need to find one that fits your anatomy.I ran into that myself, just because it was $110 saddle didn't mean it was right for me. A $49 Specialized saddle did the trick for me.
Ditto what greenhorn said. A proper fitting saddle will make all the difference in the world.
Cranking Old Guy
Turn the nose lift or right just a little to "help" with room for things!!
greenhorn
Hey...I never heard that before. Might be another trick for comfort. I guess it takes "cranking old guy" to know these things. Thanks Burr.
Cycling for life
It does take some patience and riding to get it just right. Also as you ride those "areas" seem to get tougher. Movements forward and the tilt should be done in very small increments. You will be amazed at how different 1/8 inch feels. you may also be suprised that raising the front (tilt back) helps some. Also when you will find the padded riding shorts work well. When you put them on, lift your junk. A gel pad for your seat is something else to try. Still, there is nothing that works better than saddle time.
I've had issues down there and my saddle barely comes between my legs it's at such a lean. I sort of perch myself against it and rarely sit down. If Lance can ride why can't I?
1 - 11 of 11 Posts
