Presta Valve Difficult to Pump Up
475 Views 6 Replies 6 Participants Last post by  maelochs
Hi there, i am new to cycling, i have a new road bike and it has presta valves, i am trying to use a convertor from presta to schrader converter with a stand pump, the problem i have is that the air comes out almost as fast as i pump it in and so can't reach the 100psi recomended for my tyres any advise would be welcome.
Thanks
  • Like
Reactions: 1
1 - 7 of 7 Posts
Welcome! It has been my experience that using a presta converter on a scrader-equipped pump is its own little skillset. I have done it successfully using a powered pump, but never with a manual device. In short, the angle of the presta adapter relative to the presta valve is critical. The adapter will seal to the valve, but only when held just so. There is very little margin for error. I'm sorry, but I can't describe it any better than that.
I began with a powered pump and the adapter. Experimented with the angle and physical pressure on the adapter until I heard air begin to flow. It can help a lot to separate the noisy pump from your bike as much as possible. The sound of the air flowing into the tire is much quieter than the sound it makes escaping.
I hope this helps. I haven't used that setup in some time because I found it was easier to buy a floor pump with chucks for presta and schrader valves. I still carry a presta to schrader adapter for emergencies. If budget is tight, the adapter will work with practice, but it's fiddly and frustrating, especially at first. If possible, a pump with the proper chucks already present is so much easier. If not, you'll have to practice a bit more. Not a big deal.
See less See more
  • Like
Reactions: 1
the adapter usually has a small o-ring......does yours have it?
  • Like
Reactions: 1
probably you have bought an adapter that has no rubber seal in it, or one with a seal that doesn't seal very well. Such adaptors can work OK with a compressor, but not so much with a manual pump.
BTW when pumping a presta valve using anything other than a perfect (i.e. leak-free) connection to a pump with an efficient check valve in the line, it is extremely undesirable to have the presta valve forced open when the Schrader pump is fitted to the adapter.
Presta valves are different to Schrader valves; they have the ability to open as required during pumping via air pressure alone. A presta valve ought to be opened briefly before you connect any pump (to check that the valve opens easily and is not jammed) but then should be allowed to open only when air pressure forces the valve open. This way you won't lose air when pumping, even if the connection is poor.
How to Inflate Presta Valve: Best Ways To Pump
  • Like
Reactions: 1
i have such adpter and i use a manual pump without issue......after tapping the valve before putting adapter on and with rubber o-ring on it.
Are you unscrewing the Presta head, prior to putting the adapter on?
  • Like
Reactions: 1
For very little money you can buy valve caps which convert Presta valves to Schrader for easy pumping if your pump won't cooperate. They screw onto the open Presta stem and the chuck (pump head) fits over the larger, threaded Schrader end as it would over a car tire. I used them on tours because you might need to use a gas station air pump in an emergency.
  • Like
Reactions: 1
1 - 7 of 7 Posts
