Riser block a must for riding on a trainer?
Discussion in 'Beginners Forum' started by dlucky0803, Jan 18, 2013.
  1. dlucky0803
    dlucky0803 NOOB
    33
    0
    0
    Hey guys. Need some insight. I just bought a used Blackburn Fluid trainer. I'm wondering, do I need a riser block for the front? or is the bike stable enough with just the rear on the trainer?
  2. Buffalo-jon
    Buffalo-jon Well-Known Member Tavern Member
    1,166
    189
    63
    It all depends on how you feel on it. If you feel like you are leaning forward you can either buy the block, or just take 2 foot long pieces of a 2 x 8 and screw them together and that should be high enough (3"or so) to make you level. I did this for two years in my basement. I have since moved the bike upstairs, and my son bought me the block for christmas. I don't realy notice any difference between the 2 x 8's and the block. As far as the trainer being stable enough on its own. The cyclops I own is more than enough by itself. I just felt like I was always leaning forward without something under the front tire.
  3. synack
    synack The Back Row
    2,514
    0
    36
    A roll of duct tape, phone book, etc. :)
  4. Xela
    Xela New Member Tavern Member
    3,198
    9
    0
    I used my University Physics 1 book for years. Most use it got for sure.
  5. Poolie
    Poolie New Member
    1,973
    1
    0
    Yellow pages.
  6. zero3one
    zero3one Member
    889
    0
    0
    A riser is not necessary but you will need something to prop the front wheel up so that the bike sits level. Otherwise the front end will be lower and you will put a lot more pressure on your groin and arms/hands.
    I used my trainer for a few weeks without one, I just put a bunch of foam mats underneath but I bought the CycleOps climbing riser and that it was worth the money. It keeps the front end stable and has 3 level adjustments and can even be used with a mtb tire should I want to throw my mtb on the trainer.
  7. Industry_Hack
    Industry_Hack Total noob (& forum admin) Admin Staff Tavern Member
    12,344
    632
    113
    That's comforting, coming from someone in your line of work. :)
  8. superj
    superj still learning Tavern Member
    3,610
    677
    113
    I use a piece of 4x4 cut to about 12" long
  9. Jahwarrior
    Jahwarrior Member
    927
    14
    18
  10. offrdmania
    offrdmania Frickle Frack
    462
    0
    0
    HAHA, thought I was the only one who used a roll of duct tape!
  11. cderalow
    cderalow Senior Member
    1,084
    24
    38
    I've got two of the cyclops ones stacked to actually put my bike on a slight incline.
  12. Ross14
    Ross14 New Member
    556
    0
    0
    Any kind of thick book or even just a chunk of wood, don't waste your money on a block.
  13. zero3one
    zero3one Member
    889
    0
    0
    Risers are cheap. You can find them starting at about 10 bucks. Like I said, I have the CycleOps one and I find it convenient that I can change three different levels depending on which way it faces. It also holds the wheel nicely compared to a block or a stack of books. To each his own but for some of us, it's not a waste of money.
  14. mcvouty
    mcvouty New Member
    214
    0
    0
    I agree with all the above. For stability, probably not needed. For comfort, it's a must.
    I found a little plastic box full of washers down in the basement that is just the right size to lift my front tire up. Made a world of difference on my arms.
  15. TheBiggBear
    TheBiggBear Junior Member
    16
    0
    0
    I use a couple old Cisco books with a tile on top, to give a level surface, and then my CycleOps Riser block on days I want to "ride uphill". I find the one CycleOps Riser block not enough to give any real incline.
  16. dlucky0803
    dlucky0803 NOOB
    33
    0
    0
    Thanks for all the comments. Getting together with a group tomorrow morning to try out the indoor training.
  17. baj32161
    baj32161 American Expatriate Tavern Member
    248
    0
    0
    Duct tape works for everything :D. As to the OP, I used my trainer quite a bit up here in Canada and have used trainers for a long while during the winters. I have used them both with and without a riser block. I have to say that I prefer using a riser block, as I like the more stable feel of my front wheel. YMMV of course.
    Cheers,
    Brian J.
