1 - 3 of 3 Posts
Hello everyone. I really didn't know if this should have went in the road bike forum or the single speed forum so I went here. I have a three speed road bike that I converted from a common sixteen speed. Basically, I have just removed the rear cogs and spaced the remaining three accordingly, set the der. limit screws to stop and the high and low gear, and am using a Shimano down tube shifter set in friction mode. It works ok, but I'm interested in learning more about an internally geared rear hub. I admit I am clueless on these as I have never seen or rode them in person. Would this be a better route for me to go? Do they operate more smoothly? Any advice, tips, prices, etc. you all can give is greatly appreciated.
An IGH looks like an old school coaster brake hub, as it has to be large enough to accommodate the gears. The 3-4 speeds are compact, the 7-8 are larger, and the Rohloff 14 is huge, looking like a motorcycle drum.
They allow you to shift while stopped, are very low maintenance, and other than the cable and shifter, are a pretty clean looking install, especially compared to a 3x9. The downside is weight, and possibly limited gear choices.
Discussion Starter #3
Thanks for the info., IH. The three speed is what I would be interested in. I'm already using a shifter and cable so that doesn't matter much. I would think that I may be a tad lighter going the standard road hub and just three cogs, but don't know for sure. The cogs I am using now are a 21, 18, 15...
1 - 3 of 3 Posts
