Hi,
I've always had a problem when lubricating my bicycle chain, I could never tell where I started to apply the lube. I now have a solution. I lace a piece of string though one of the chain links and tie it in a tight loop. I use the string as a start / stop indicater. The string will pass through the shifter with no problems. I apply the lube and then remove the string.
BobH
BobH
