1 - 9 of 9 Posts
I just got a used rode bike and the tires are new. It says to inflate to 120 psi but at 100 they are tight. DO they still need to be at 120? I'm afraid they'll pop.
I've been riding mine around the value recommended by the chart (105 to 110 instead of 120) and it has only been a positive difference. The ride is much smoother now, and I actually think it corners better because some of the small bumps are being soaked up by tire deflection.
Eocyclist
Here are four sites that talk about inflation pressure.
You need at least enough pressure to keep from getting pinch flats when you hit a hole, but not so much pressure as to blow the tire off of the rim, or experience an extremely rough ride.
From tire manufacturers
Schwalbe Tires - North America
Michelin Bicycle Tires - USA
Other opinions:
Sheldon Brown - All About Bicycle Tires and Tubes
http://www.bikequarterly.com/images/TireDrop.pdf
Personally, I would go with the tire manufacturers rather than the other opinions.
GiddyUp
Depends on your weight and the tire specs. With tubeless tires you can run a little lower pressures because you don't have to worry about pinch flats. With clincher tires (tubes) you still don't want to max out the pressure, for instance Vittoria says you can inflate some of their tires up to 140psi. Unless the road is smooth as glass you are going to get lower rolling resistance and you'll have a teeth chattering ride. You'll spin longer with lower pressures and you'll spin smoother also, but you can't go too low either. You just have to figure out what that "sweet spot" is for you. For me it's between 95-100psi on Fusion3 tubeless tires.
M. Westmacott
This is really helpful, thanks for sharing,I've been doing it all wrong for years, maybe my tryres will last abit longer now ! all the best, x
1 - 9 of 9 Posts
